jdx ignition problem
redneckchicken
Post by redneckchicken »
i had my 74 jdx8 running earlier this fall it was running fine but now i can only get spark off of one coil at a time i have to switch the #1 wire coming from the engine between coils to get spark. i took a test light to the #1 and #2 wires coming from the harness the #1 has a bright light and #2 a dim light. What is going on i'm beyond confused.
JDFanPa
Post by JDFanPa »
the points need to be cleaned on the no spark side
Deleted User
Post by Deleted User »
Did cleaning the points solve youre problem?what happens if the condenser is bad.
