1977 skidoo rv cross country
Well i picked up a 1977 skidoo cross country. Planning on getting it cleaned up and ride it as is. It doesn't have the correct seat or gas tank and the motor is question able if it is correct. It doesn't have the right cylinder head on it. It used the 77 340 snopro motor with lower rpm pipes on it. It had a gas tank in the rear of the seat as well. The first picture is what it is suppose to look like so if anyone knows of a seat and tank I'm intrested. Mine is a little rougher but something good to work with. The heat exchangers run down the sides of the tunnel. They only made a couple hundred of them.
- ihengineer76
- Real Name: Tom Rehberg
Re: 1977 skidoo rv cross country
Way cool!
