Hello everyone,
I bought a really nice Liquidfire, completely rebuilt and runs great. One problem though, I went to put a full tank of gas in it and it leaks at the rubber seal where the fuel nipple is. I have always dealt with Midmount machines, easy fixes. I need some info as to how I go about fixing this problem the correct way. Thanks everyone.. BTW, all of the hardware is new including fuel lines, the fuel nipple, etc etc... Thanks..
Mike
Need help with a 1982 Liquidfire
JD Midmount
Big Mike
Owner of:
JDX4 Special
JDX4
JDX8
1972 JD400 x 2
1982 Liquidfire
Owner of:
JDX4 Special
JDX4
JDX8
1972 JD400 x 2
1982 Liquidfire
Re: Need help with a 1982 Liquidfire
That rubber tank bushing is still available from Deere. Part # is M149638. Call up to Mid-State in Columbus. They can get you one in a couple days if they don't have them in stock.
- jdrob
- Real Name: Rob
Big Mike first try what discus shared and while replacing it, check the hole in the tank were the grommet goes and make sure its not cracked or made a little bigger? I had 1 on a sportfire that would continue to pop out. I ended up replacing the tank.
Tanks are easy to find, If you need 1 let me know I will give you 1 for free, just pay for the shipping... Jdrob
Jdrob
JD Midmount
Thanks Guys.. I am calling Mid State as we speak.
Big Mike
Owner of:
JDX4 Special
JDX4
JDX8
1972 JD400 x 2
1982 Liquidfire
Owner of:
JDX4 Special
JDX4
JDX8
1972 JD400 x 2
1982 Liquidfire
