295 stripe
295 stripe
the stripe on the tunnel on my 295 is solid yellow like the other mean green sleds unlike the hood which has the yellow black yellow black . is there any way this is factory or has the tunnel been painted at some point . it looks like the original paint but maybe not? thanks for your help wade
- Real Name: Tom Schuster
Re: 295 stripe
Both my 295/S sleds have the solid yellow stripe on the hood and the tunnel. My buddy has 2 with the yellow/ black stripe. I think this must have been a factory serial number break change. I think the earlier ones had the 2 color stripe. Maybe someone else has some input also. Tom
Re: 295 stripe
I believe that there was a post about this about 3 or so years ago?? don't remember now what the out come was
Grumpy
Grumpy
Re: 295 stripe
Yes, there was definitely a point mid-production when they changed the decal. However the hood and tunnel would have the same one. Maybe your hood was swapped, or one of the stripe decals was replaced later in life.
Re: 295 stripe
It would be nice to know the serial # break on this... Mine has solid yellow on both tunnel & hood. Serial # is in the upper 700's.
Re: 295 stripe
I was looking at the registry - and can't really see a pattern. It's like they switched back and forth.
- JDXspec
- Real Name: Dustin
Re: 295 stripe
If remember the dicussion right I have the latest known serial # thats original with the yellow/black stripe Mine is in the high 500s. Looking at the registry he ones that are later than that with the yellow/black stripe are restored which could have easily gotten the early stripe. I have has 5 295s over the years and the late ones I had were in the 700-800 all yellow and the ones with yellow/black were in the 500s. All were original to my knowledge.
Re: 295 stripe
mine is 623 with a solid stripe! wade
- JDXspec
- Real Name: Dustin
Re: 295 stripe
The one I just picked up 2 wks ago was 586 and I bought it from the original owner- Has the yellow/black stripe
Re: 295 stripe
makes it sound more and more like 600 may be about the cut-off !! wade
Re: 295 stripe
I have 995 and it has a yellow/black stripe. It looks original.
Re: 295 stripe
I have 955, it is unrestored and it has the yellow/black stripe.
Re: 295 stripe
it sounds like they used whatever they had laying around!! wade
