Wanted 76 liquifire parts
440 rat
Post by 440 rat »
I'm looking for an original 76 liquifire rear grab handle, two up seat back, and frame. Also If someone has pictures and measurements for the wood seat frame, so I can make a new one that would be great.
Re: Wanted 76 liquifire parts
Rear Grab Handle? Are you looking for a rear grab bar that runs from side to side or the black grab handles on each side of the tunnel? If it's the latter than you most likely won't find any "original handles" with three holes however the grab handles are available at several different sources with one hole and you just have to drill out the other two. No big problem. I always keep a pair in stock for restorations.
Don O
Post by Don O »
440Rat
If you are looking for the chrome side handles and the back rest supports I have a set, came off a 76 Cyclone. Some rust and pitting on them.
Once mounted you can easily determine the size of the backrest.
I'm in the Detroit Lakes area, same state if that helps.
Don O
440 rat
Post by 440 rat »
WinnipegStPaul9 wrote:Rear Grab Handle? Are you looking for a rear grab bar that runs from side to side or the black grab handles on each side of the tunnel? If it's the latter than you most likely won't find any "original handles" with three holes however the grab handles are available at several different sources with one hole and you just have to drill out the other two. No big problem. I always keep a pair in stock for restorations.
I have the black plastic handles, I need the tube that bolts to the rear of the tunnel and goes across the back of the machine. I guess its a rear grab handle.
440 rat
Post by 440 rat »
Don O wrote:440Rat
Don O
Any pictures and a price?
Don O
Post by Don O »
440 rat,
I don't think you want the set I have, too many problems, twisted off bolts and they won't come out.
I think the bumper that Kenny repopped last year would work for you.
Don
