Head torque on a polaris 440 fuji
I'm working on a 1997 xcf 440 fan. My question is (and maybe I'm losing it and can't see something) how am I supposed to torque the head in the correct sequence when there are 4 cylinder head nuts that go on the top side of the metal shroud (that hold the shroud to the head) and the rest are bolts that go into the cylinder are underneath the metal shroud. It is similar to a trailfirebut the TF uses a double threaded nut for the head to attach a screw through the shroud to the nut. The fuji does not. I hope this makes sense? Sorry. I'm confused? Am I missing something? I can send pictures if needed.
Re: Head torque on a polaris 440 fuji
They may be torqued to different specs if they are different sized bolts or nuts. Any polaris dealer would answer your question.
- 69camaro
- Real Name: Duane Gjerseth
My nearest Polaris dealer would tell you to figure it out yourself. No kidding.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
There is a repair manual on my site that covers it. Www.vintagesnow.com
