I think I will do as suggested and swap the carbs.
I have entered all my sleds in a rally / show and shine for this Saturday and the LF is the nicest one of the bunch (other than it runs like crap at the moment).
Is there any chance of burning this thing up if it has a blown crank seal or will it just run bad ?
81 Liquifire CDI with intigraded coils ????
- GreenGenes
- Real Name: Terry
Re: 81 Liquifire CDI with intigraded coils ????
1973 JDX-8
1974 JD300
1981 Liquifire
1981 Jag F/A 340
1974 JD300
1981 Liquifire
1981 Jag F/A 340
- Real Name: Greg Cyrocki
I would say its a good chance if it is in fact a bad crank seal.
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'83 Sprintfire (wife's sled )
'84 Snowfire
'88 Yamaha Sno Scoot
'71 Massey Ski Whiz Special
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
- Real Name: Lloyd
There is a huge chance of blowing it up if you run it with bad crank seals
Not only will it run like crap, (if you can get it started) You run the risk of it leaning out and blowing a piston.
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Before or after the usual coding?nick80lf wrote:The factory updated 81s were stamped with an "A".
- GreenGenes
- Real Name: Terry
Would anyone know the Kimpex part # for the crank seals. I'm in Toronto this week and can drop by Royal Distributing to pick them up. Work all night Friday to do the rally on Saturday.
1973 JDX-8
1974 JD300
1981 Liquifire
1981 Jag F/A 340
1974 JD300
1981 Liquifire
1981 Jag F/A 340
AirborneX4Special wrote:Before or after the usual coding?nick80lf wrote:The factory updated 81s were stamped with an "A".
I saw an older post that said it was after the date code. I've never seen one of updated 81s. Hoping someone that has will chime in.
Winderosa 501302R, 501411, 501453, one of each.GreenGenes wrote:Would anyone know the Kimpex part # for the crank seals. I'm in Toronto this week and can drop by Royal Distributing to pick them up. Work all night Friday to do the rally on Saturday.
- GreenGenes
- Real Name: Terry
Thanks Matt. Just a question why 3 seals?
1973 JDX-8
1974 JD300
1981 Liquifire
1981 Jag F/A 340
1974 JD300
1981 Liquifire
1981 Jag F/A 340
One is the oil seal for the oil pump drive cover
