'78 Invader 440
'78 Invader 440
I bought this one about a month ago. The previous owner did some work to get it running. I had to replace the brake disk and pads and jackshaft bearing while I was at it. It needs some help with sloppy steering, but it seems like a pretty solid sled. This is the second Invader I've bought off CL within 15 minutes of home. I would be great if more JDs showed up close to home for reasonable prices, but there seems to be a lot of Kawis in the area.
ljm
- Real Name: Lloyd
Re: '78 Invader 440
That sled looks good !!
What year is it?
Lloyd
What year is it?
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Re: '78 Invader 440
1978 - first year Invader, and first year they rolled sleds out of the Kawasaki USA factory, correct Lloyd?
ljm
- Real Name: Lloyd
Re: '78 Invader 440
Hey Matt.
I know the Kawasaki/Sno-jet models were built by Cat. I'm not positive, but I think at least some of the first Invader's were too. I can't seem to find the article I read years ago about that.
That one looks in great condition.
Lloyd
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Re: '78 Invader 440
I was under the impression that it was just the smaller models (Drifter, Enticer, etc) that were built by Cat, but the Invader/Intruder chassis sleds came from Kawi's own plant.
It's in pretty good shape. There is one spot in the hood where the secondary rubbed through it - I guess the bolt backed our or something. It's a little cracked on one of the corners too.
Re: '78 Invader 440
Looks to be a fun ride!
DeereKid9
- Real Name: Bob Amber
Re: '78 Invader 440
I see a kawisleds.com in the future.
Sent from my SM-T217S using Tapatalk
ljm
- Real Name: Lloyd
Re: '78 Invader 440
A huge percentage of Invader/Intruder hoods have the hole rubbed by the secondary.
Where is the slop in the steering?
Lloyd
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Re: '78 Invader 440
Don't need to, Kawasakitrax has been around for a long time.DeereKid9 wrote:I see a kawisleds.com in the future.
So far, I see there is slop spindles to the skis (I replaced the bolts, the bushings probably need to be next, and I think the holes in the saddles are worn too) the arms on the top of the spindles seems loose, and I don't know about the lower bushing on the steering shaft yet. I see the engine has to be pulled to get to that.ljm wrote:Matt
Lloyd
BTW, this sled does have 3500 miles, so the wear isn't a surprise - it's a bigger surprise that the suspension brackets aren't broken or even cracked.
Re: '78 Invader 440
Great looking sled Matt, Congratulations !!
ljm
- Real Name: Lloyd
Re: '78 Invader 440
BTW, this sled does have 3500 miles, so the wear isn't a surprise - it's a bigger surprise that the suspension brackets aren't broken or even cracked.[/quote]
Matt the suspension brackets might have bee replaced or it has been a trail sled.
The arms on the top of the spindles are an issue with those. I'm not sure of a good fix. There are some NOS arms and spindles kicking around, but harder to find than Deere stuff.
Are the bushings seized in the bottom of the spindles?
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Re: '78 Invader 440
Lloyd, I got one side out, the other side is still stuck at the moment, but I didn't try that hard to get it free.
