'97 Polaris 680 Indy ultra sp rebuild question
Dillymann
Post by Dillymann »
Im thinking of buying a 97 Polaris Indy that has high miles and am wondering how much its going to cost to rebuild the top end
Sent from my iPod touch using Tapatalk
SnowCrossMark
Real Name: Mark
Post by SnowCrossMark »
$300 plus per cylinder . It might need a new belt, new clutches, new gas ($) shocks, track, idler wheels, water pump. $780 for water pump. 525 pounds of can't turn, doesn't stop well, doesn't hook up, and don't ever drive on a side slope. And this is the real thing it's very, very difficult to work on with all of these parts tightly packed in together. Repair manual is 600 pages of English translated into Japanese and then translated back into English I can't understand it.
In other words forget about it. Consider a 1977 Liquifire, truly worthy sled.
Welcome to the site. - Mark -
Last edited by SnowCrossMark on Thu Mar 20, 2014 2:27 pm, edited 2 times in total.
1977 340 Liquifire, 2 - 1978 440 Liquifires, 78 cc Clone(#35),
1997 Polaris XCR SE 600 (mistake).....
#400v
I seemed to have been a much better driver when my sled was slower.
Dillymann
Re: '97 Polaris 680 Indy ultra sp rebuild question
Post by Dillymann »
SnowCrossMark wrote:$300 plus per cylinder . It might need a new belt, new clutches, new gas ($) shocks, track, idler wheels, water pump. $780 for water pump. 525 pounds of can't turn, doesn't stop well, doesn't hook up, and don't ever drive on a side slope. And this is the real thing it's very very difficult to on with with all of these parts tightly packed in together. Repair manual is 600 pages of English translated into Japanese and then translated back into English I can't understand it.
Just for parts ?
croyturbo
Real Name: Chris
Post by croyturbo »
I did a 600 and was 1200 with new sleaves pistons and gaskets.
Chris
Dillymann
Post by Dillymann »
All the used sleds i can find in my price range have 5000-10000 miles on them
Dillymann
Post by Dillymann »
Will they need a rebuild if they have been serviced regularly ?
sledder670
Post by sledder670 »
It really depends on what it all needs. How far do you want to go, cheap pistons or wiseco, polaris clutches are pretty solid. I have torn some apart with 7000+ miles and just need new buttons on the primary and secondary might want new springs also. Check the front suspension especially where the trailing arms arms connect to the tunnel. I have seen them broken and just dangling in the belly pan. As far as the motor if its still running I wouldn't touch it they used plenty of oil.
Dillymann
Post by Dillymann »
sledder670 wrote:It really depends on what it all needs. How far do you want to go, cheap pistons or wiseco, polaris clutches are pretty solid. I have torn some apart with 7000+ miles and just need new buttons on the primary and secondary might want new springs also. Check the front suspension especially where the trailing arms arms connect to the tunnel. I have seen them broken and just dangling in the belly pan. As far as the motor if its still running I wouldn't touch it they used plenty of oil.
Thanks alot
