19H3459: 13.5" center bolt
08H4497: Front cross bolt
24H1730: Rear axle idler washers
24H1909: Center idler 1/4" thick outer washers
I knew the center bolt was availble, but I didn't know about the washers and front bolts. The 82-84 skids use cross bolts in places the 80-81 just uses shorter end bolts. Only downside is that some of this stuff is the gold zinc color vs the orginal silver. It wont' affect the race sled, but isn't exact for the resto, but they are part number correct.
With the new hardware installed, assembly of the suspension is about complete. Need to finish rebuilding the idler wheels with new bearings to finish her up...
