tuning a kec 340/22
tilley7658
tuning a kec 340/22
I have a 1976 or 77John Deere 400 with a kec 340/22, i had great difficulty with the walbro carb , and have since switched to a 36mm mikuni , it seems to start great now and run ok, the first time with the new carb it was pretty peppy to about 3/4 throttle and giving it a primer shot of fuel did not seem to help, and on the second ride seemed to continually need primer shots of fuel to stay running, have i overlooked something? carb settings are 280 main 40 starter jet mix screw is about 9/16 open and needle clip is in the middle , any help would be greatly appreciated.
- 69camaro
- Real Name: Duane Gjerseth
Re: tuning a kec 340/22
Did you install a fuel pump?
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
tilley7658
ya it has a brand new mikuni fuel pump, when it was stalling last year it had good air pulse for the pump. but will check again hot and cold. Thanks guys .
im with jdt id check your crank seals etc but a 280 jet isnt going to be big enough , according to the parts manual a 34 cyclone with a 34mmcarb had a 370 main jet in it from the factory that should be the same motor as what you have , im guessing it will take an even bigger jet because air fuel velocity will be slower in your larger carb , i would address your situation before you burn it down as it seems you have a very lean cobination wade
tilley7658
Thanks for the help All , special thanks to Wade, got that sucker running sweet.
Ian
Ian
Can you share what your jetting ended up as? Is the sled still running, no burn downs?
Steve - RootsTXL
Steve - RootsTXL
