For the most part, the rear suspension is complete. I need to address some of the details and decide what I am going to use for the upper idlers wheel on top of the rear arm. I have an OK set of original Capital Stampings units that would need paint. But Matt can get small idlers that are only slightly larger than the original 4 1/8" diameter ones. I am also checking with my buddies to see if I can scare up a set of NOS Capital Stampings units.
For now, the suspension was bagged and set aside to resume work on the chassis.
Allen, using a little heat is by far the best method I have found to pull decals off the tunnel or other metal parts. Brock Weber, the member here who restored the 78 Liquifire HoF charity sled, suggested it when I was stripping down my race sled last year. It was really good advice.
Even with the stickers removed, it can leave some adhesive on the tunnel. I sprayed it down with some "Aircraft Adhesive Remover" and let Cari Deerest at it with a putty knife:
You can see under where the sticker covered how polished the tunnel was originally. I may go for a mirror shine, but I am not sure yet as I was hoping to go with an original look...
Luckily for me, Cari doesn't mind lending a hand working in the barn, packing gear bags or help loading the trailer. Now if I can only get her to sand blast and rebuild motors...
Progress on the 84 has slowed down with having to get the racer ready for the Vintage I-500 class. But, it has not stopped. Spent some time straightening a tweeked ski and getting the pair blasted and coated:
After blasting, they were dropped off for coating:
With some help from my bestests buddy Brock, I was able to obtain 4 NOS 6 3/8" idlers, and a set of Capital Stampings units for the top arm. These will look much better than the rebuilt idler wheels I tried to clean up:
In return I had to promise Brock a lifetime supply of rusty JDX-8 bogies wheels. He drove a hard bargin, but a fair one...
With help from a hauling customer I was able to obtain the NOS Liquifire track from Dustin Smit. Picked it up on my way home from the HoF show. About the only other parts I think I need is a set of repop decals and a low windshield.
Next up is polishing the tunnel and getting the re-assembly started.
