Liquifire motor in a cyclone
Viktory2k1
Post by Viktory2k1 »
Hi, been a while.
I ran across a liquifire motor(looks to be 77)and was thinking of putting it in my 77 Cyclone. Do You think this is an ok idea or leave it alone? Just looking for opinions.
Now I can't upload a photo, file too big. I thought site used to resize.
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
Re: Liquifire motor in a cyclone
I personally fail to see the value of making this change.
ljm
Real Name: Lloyd
Post by ljm »
x2
Several Deere's
Several Kawasaki's
ACSCC #1534
It is possible but you would need to do a few things to make it work.
Cut up the tunnel to install the 76/77 heat exchangers and install the correct hood. The vents are different from the cyclone. You would also need the correct liquifire seat.
I agree with Don, why bother.
Jimmy
Real Name: James Lalk
Post by Jimmy »
I have one. Bought it at Hay Days two years ago for 175.00, I call it my "SLEEPER"
James Lalk
Sumner,Ia
mfd1221
Real Name: Jim Cieply
Post by mfd1221 »
With enough time and money I believe you can put any motor in any chassis. We are in the process of putting a M11 cummins in a F550, we already put Peterbilt low air leaf on this truck. It all depends on what you want.
Den
Post by Den »
Here's where I started.
I swapped out a slot car motor for a "stomper 4x4 with working headlights" motor.
I could melt the tires right off that slot car.
It only got worse from there. Putting a 79 Mustang motor in a Ford Ranger, etc.
Anyway, I guess you got your answer.
Looks like you COULD with the right mods, but will it be worth it is up to you.
HoosierDeereMan
Real Name: Troy Miley
Post by HoosierDeereMan »
Vic,
The Liquid cooled engine will drop right in with no modification. You would have to make sure your gas tank has the clearance in the bottom of it to accept the heat exchanger tubes. You would also have to find the heat exchangers for under the seat and modify the seat board and foam to accept them. There is roughly 10 hp difference between a 340 Cyclone and 340 Liquifire. Same holds true for the 440s. If your Cyclone has a /22 engine in it, I would install the dual carb intake, carbs, and air box from the Liquifire. I would also install the Liquifire exhaust pipe. You would save the weight of the liquid engine and heat exchangers while gaining horse power. Just my opinion.
Troy
ljm
Real Name: Lloyd
Post by ljm »
In my mind Troy has the best suggestion. If you counted your time worth $5/hour it would be cheaper to buy a Liquifire chassis. But the dual carbed Cyclone would make a great sleeper
Several Deere's
Several Kawasaki's
ACSCC #1534
I500
Real Name: Chuck Moser
Post by I500 »
I guess I just don't understand this sleeper thing. Makes no sense to me.
Is it workable to put dual carbs on a Cyclone? If the motor will put up with that it seems like a better choice.
TASKY
Post by TASKY »
I500 wrote:I guess I just don't understand this sleeper thing. Makes no sense to me.
Chuck thats race sled talk.
Missed you in Duluth, saw your sleds though. Even the Motoski.
ihengineer76
Real Name: Tom Rehberg
Post by ihengineer76 »
AirborneX4Special wrote:Is it workable to put dual carbs on a Cyclone? If the motor will put up with that it seems like a better choice.
I have done it in the past, and it works well. Use the carbs, airbox, and intake off a Liquifire. The pipe would require a little modification to make it fit the angle of the fan cooled motor, but it's not that hard. It definitely wakes them up at the higher RPMS.
