82 Liquifire Restorations
Re: 82 Liquifire Restorations
Seats finished today. Looks to be a bit on the powder coated items. Winter is a busy season it seems.
1980 Trailfire 440 (parts sled), 1980 Trailfire 440, 1982 Trailfire 440 1976 Liquifire 440 (Project), 1976 Liquifire 340 1982 Liquifire, 1982 Liquifire (Project), 1983 Snowfire, 1983 Sportfire
Parts are starting to come in and come have been cleaned. Told my wife was just going to assemble it in the storage room
Finally got things loosened up enough to split the crank case. Not sure if this is salvageable or not. Letting it soak now. Scrubbed a lot of the corrosion off. Center does spin, Bearings are seized.
Not sure. This was seized so started on it first. Wanted to keep the other one together less i forget how something goes back together. Other engine turns so it should not be nearly as bad. Crankcase is just as bad. Hoping it will come clean. Could be my luck that will have a new top end and no bottom
- Danzig
- Real Name: Paul File
CB helped we out with a new bottom end. Hoping to get parts back from Powder Coating tomorrow. And located an HSRI coil? So should be in business soon to start reassembly :-)
A little more progress. Will be able to start putting the frame back together next weekend if luck holds out
Made a little progress over the weekend.
fastl82vette
- Real Name: Greg Cyrocki
Looking good!!
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'83 Sprintfire (wife's sled
'84 Snowfire
'88 Yamaha Sno Scoot
'71 Massey Ski Whiz Special
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
It's coming along nicely Nathan!
Little more work over the weekend. Seems the dog hair and dust attacked what i already had
Either way will get thinks washed up after a bit. Still need to track down boots for the carb to the airbox and need to find the airbox hose. Put on an electric start so will see how things go once the carbs are done soaking for the night and cleaned up.
fastl82vette
Looks great!! It's been a wonderful week to work in the garage!!
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
It's looking good Nathan, The airbox mounts right onto the carbs with hose clamps. You wont need rubber boots.
