'79 Trailfire No Spark
Re: '79 Trailfire No Spark
An ohm meter setting is what you need, you should be able to get all your resistance readings from the wires outside of the motor.
Ok. I checked the pulsar coil and got a reading of 21.8 ohms. Is that good?
Yes, per the diagram I posted before, which says 23 ohms +/- 20% across the red/white wires, so at 21.8 you are good. How about the red wire to ground? Should be 128 +/- 20%.
With the red wire to ground, I got 141.2 ohms. Starting to think its the cdi at fault. What do you think?
I was also wondering if a cdi for a 1980 Trailfire would work on my '79. It seems like it should, because I thought they have the same engine.
- Packers29
- Real Name: Andrew Engels
Yes it will work.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Does anyone know a good place to get a cdi?
If you aren't sure how to do the ohm test I'm sure there are some videos on you tube that would help you.
Now I see you figured it out. I missed the second page of the thread.
I ordered a cheap cdi box on-line last year and it worked ok. It was black plastic instead of metal, but it seemed to work ok.
I think I found it on e bay.
Got it running!! Bought a kimpex cdi off ebay and put it on last night and it runs great now, but I wish I had some snow. Thanks guys for the help.
