Jd 400 carb change
monte44
Jd 400 carb change
Post by monte44 »
Has anyone done a mikuni swap on a jd 400? Just wondering? Thanks.
Re: Jd 400 carb change
A number of guys have. With a 34 Mikuni, a 25 pilot and a main in the low 200s should be in the ball park.
Corey JD400
Real Name: Corey
Post by Corey JD400 »
Hi there
Did you do the swap? If so how does it run? What was your final setup?
I may be doing the same shortly
