440/22 cylinder bore specs.
- BlazinC5
- Real Name: Devin
So, looking through the online manual. I am a bit confused at what I read. I see the specs for the 800/X8. And it says cylinder bore is to be 2.6000"-2.6007". Ok. Tolerance column says .005" hmmm. That means my bore can be 2.6057" and still be in spec. Correct? My bore on the one jug I pulled is measuring out at about 2.6018-2.6031... l seam to be good with a hone job if that's true. The piston, I think is needing replaced. A quick measure looked like it was small. And out of tolerance. So next question. Denniskirk.com the best place to get pistons? They have parts unlimited brand.
1975 JDX8
1972 500
1972 500
