There has been at least 3 questions the past week on "where can I get these"...so here goes........this part is the small white nylon washer (John Deere M68270) that fits onto the long jet needle. It seats into a machined recess on the top of the slide valve, and under the throttle cable retaining plate. An exact replacement can be purchased from Arctic Cat, P/N 6505-437, about 90 cents each as of late 2006. Fit my 80 LF powerjet carbs perfectly. Arctic Cat shows the same part number for VM 34's.
Note: Most non-tuning componets are common between VM36's & VM38's including the rubber mounting flanges.
Mikuni Needle Jet Nylon Washer/Seal
Posts in this forum are limited to approved members to keep things clean. If you have a question about a topic here, please post it in the appropriate tech section.
