The brake disc has some rust on it, but once the sled runs again the rust will wear off.
But not the center of the brake disc, so I painted it with same heat paint as I used on the Y-pipe.
Not a perfect circle, but who cares
The paint needs to be exposed to heat for one hour to be hard.
So when the girlfriend was not at home, I used the oven like just a man can...
The shield above the brake disc is missing, so I had to make one.
Brake and speedometer drive mounted. And the shield fits perfect.
On the other side of the drive shaft I put some copper paste on before mounting the secondary clutch,
