ANOTHER SLED PROJECT... SPRINTFIRE #2
Re: ANOTHER SLED PROJECT... SPRINTFIRE #2
Thanks JDTJDT wrote:That turned out real nice.
I went on a treasure hunt to earlier owners and possessors of this led, and i got home with the gas tank and the seat.
Gas tank is in good shape, but with a worn fuel line connection and a bad gas cap.
The seat has some cracks in the cover, but is in very good shape anyway...
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
While waiting for some new parts, I have done different small things on the little Sprintfire...
I did a really good cleaning of the gas tank, and then some magic to get the shiny black back again
Before...
After...
The gas cap did not get any cleaning, I have ordered a new one.
Before...
After...
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
- Real Name: Chris Farrell
that tank turned out great. Always wanted to try that method with the heat gun, but always to scared to wreck a decent tank.
79 spitfire. 78 cyclone 440
76 liqufire 340. 80 liquifire
76 liquifire 440 x 2
I'm sure that you have some old car near you with bumpers or doormirrors that has oxided and getting white, try the hot air blower there. It's not hard, you see directly when it's enough
But if you try it on this type of gas tank, don't try to heat the black back on the compartement lid. It's not that type of plastic, it vill be burned and shrink.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
I have started on the motor. I'm gonna take it apart to mount new crank seals, measure the cylinder port size and durations.
So the intake, Y-pipe, starter and cylinder head comes off...
Duration check
Pistons opens the transfer and exhaust port almost all the way.
But on the intake side the port opens full
After checking the durations, I took the crank out. The seals looks very good, but will be changed. The little O-ring seal on the bearing in the middle was gone, so I have to order a new one.
The empty motor is ready for sand blasting.
Duration check
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Looks fantastic!!
Thanks!jep_800 wrote:Looks fantastic!!
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Today I did some job on the skid.
Cleaning the rails. Changing bearings in the wheels. Sandblasting and painting the steel details on the skid. I also mounted grease fittings.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Don't forget the limiting strap. I don't see it in the pictures.
Beautiful skid!
