Now to install the leaf spring mounts to the spindles. I will be Installing generic ski spreaders that i Had laying around. for the stk class i really don"t need anything special. They help out tremendously to add stability in the corners. How I will be mounting these is a bit different than your average sled, Although I would not recommend ski spreaders on a trail sled.
Here Is the left side. As you can see the spreader is bolted flat to the spring mount as you would typical mount them. Also a new bushing-bolt kit from DA over at busco bullet. love those kits.makes the mount to the spindle nice and tight. Id recommend everyone to purchase them for all jd sleds. Proud to have Busco Bullet Inc. as a sponsor this season.
Now for the right side, Will be a little different. I was given some shims from a fellow racer last season to give my right ski a negative camber. Unbelievable what a difference they make. The sled basically steers itself in the corners. That is Great so I can concentrate more on the track vs trying to muscle the sled around the ice. Also allows you to carry a lot more speed going through the corners.
Here they are. Buddie purchased them from Fastenal. The are a 2 1/2 degree shim designed for aligning structural steel beams in buildings. They come in raw steel form so I have these powder coated as I do most all parts on this build.
Here is a side view of them
79 spitfire. 78 cyclone 440
76 liqufire 340. 80 liquifire
76 liquifire 440 x 2
