ANOTHER SLED PROJECT... SPRINTFIRE #2
SS440-80
Real Name: Robert
Re: ANOTHER SLED PROJECT... SPRINTFIRE #2
Post by SS440-80 »
jep_800 wrote:Beautiful skid!
Thanks Jason :beers;
TASKY wrote:Don't forget the limiting strap. I don't see it in the pictures.
I believed I could sneak in the almost done skid picture without anyone noticing that the straps where missing... :wall:
But today on my lunch break I mounted the straps (I use two) and took some pics :D
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
SS440-80
Real Name: Robert
Post by SS440-80 »
With the motor sand blasted and painted it's time to assemble it again.
First honing the cylinders
New cylinderbase gasket
New o-ring on the centre bearing on the crankshaft
Original Sprintfire-pistons. Used but in good shape.
Of course new needle bearings and crank seals
Top and bottom back together again...
Stator och flywheel
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
acesillini06
Real Name: Matt Cappel
Post by acesillini06 »
Excellent detailed pictures. Looking really good. Bring those Sprintfires back to life!
Very nice work!
SS440-80
Real Name: Robert
Post by SS440-80 »
Thank you boys :usa:
I try to show a lot of pics. Maybe to many sometimes, but if they can help anyone it's perfect.
Did a couple of hours on the motor tonight.
First I had to extend the right ignition cable. Soldering and thick insulation
And new spark plug caps
Went trough the water pump and oil injection pump, making sure they work. Mounted it and the starter cage/ belt pulley
New oil lines
Starter
And engine mounting plate
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
The motor is almost ready to go back in to the sled, but first I have to make the chassie look better :D
The tunneln has been stripped from the original stripes by a previous owner, and then painted with some strange silvery paint that wont come off even with thinner. So I make it easy for me and wrap with same type of folie that the pros use on cars...
The aluminium above the fotrests also had the same strange painting, so I practiced on them.
Then the tunnel
Not to bad for a wrapping rookie
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
TASKY
Post by TASKY »
I saw a Sprintfire once in all black, belly pan and all. It really looked nice.
SS440-80
Real Name: Robert
Post by SS440-80 »
TASKY wrote:I saw a Sprintfire once in all black, belly pan and all. It really looked nice.
A all black would be super cool :D But I don't think that a painted belly would look so nice after a season here with our narrow trails in the forrests... But the hood will be painted in high gloss black. If there will be any stripes.... I don't know yet :?:
The foot boards on John Deere ain't by far so soft as on old Yamaha sleds, but the aluminium rail grip is so good and makes the board so much stronger so I put them on the Sprintfire anyway :P
Stabile :dance:
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
The original Sprintfire gas cap was in bad shape, so I bought a new gas cap that I had to shorten the gauge 5cm (2")
Then I made a new bottom for the compartment in the gas tank
Gas tank back on the sled
The seat had some cracks in the cover, but I made a quick repair of the cuts. My plan is to make another more sporty type of seat later, so a cheap repair of the old one will do for now.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
The Y-pipe was rusty
and had some big sharp edges inside
Now the inside is grinded smoth and the outside is painted with heat paint
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
I mounted the skid back in the tunnel again, but I was not happy with how tight the track was. It's the big drive sprockets that causes this. And even tough the skid mounting bolts has been moved forward 6cm, I can't press the rear skid wheels enough to let the track pass freely.
So I have to make new drive sprockets...
I bought a piece of POM (other names are Delrin or Acetal) that I now will machine to drive sprockets with 9 tooth instead of the ones I have now with 12T.
First I have to make the ends of the peace straight
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
So now I have made a prototype... :think:
I used the piece that was over when I cut of the two who's gonna be the drivesprockets. The left over piece is almost a half drive sprocket, just one millimeter to thin.
Made a mallet from a piece of wrapping foile
Just to get a image of the shape
Some thinking and measuring and then the lines for the axle was there :D
Cut of a metal pipe to get a 10mm ring to enforce the plastic where the axle will go in to the sprocket.
Some milling and some spins in the lathe, and the ring fitted like it was glued on :mrgreen:
A metal plate to get a good line when I'm milling around the teeth
Sprocket now taken down in size to the right diameter. I decided that the calculated diameter for 9T with 3,29"/2 pitch and then 9mm taken away so that the track can curve around the sprocket :think:
The rounding of the teeth marked
Teeth rounded and the centrum hole drilled
Drive shaft hole milled as close as I could, but the final touch I had to do with a rasp.
And here the "half" drive sprocket is mounted on the drive shaft. So now I just have to do the two sprockets I need for my sled.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
TASKY
Post by TASKY »
You must be very committed to that track to make custom drivers for it. Are the new sprockets around the same diameter of the stock ones so as to remain in the stock gearing neighborhood? Just an idea, a guy could make them in 2.52 pitch so a modern track with thinner rubber belting could be used? Maybe this would give a little less rolling resistance? I am envious of your machining skills.
SS440-80
Real Name: Robert
Post by SS440-80 »
Time goes fast when the winter comes early, and I have been riding my new Lynx Boondocker alot and also been out on my vintage sleds much :D :D :D
But I have been working some on the Sprintfire and on my ET440 to, but I have not taken the time to update the threads.
The new drive sprockets is done...
Yes, even mounted
And the skid is there too
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
One ski rubber damper was missing, but I found a rubber for a Ski-Doo that looked like it could fit with some modifing.
With the rubber dampers and ski spindles mounted it's time to make the skis look better...
Skis painted, new plastic ski skins and runners.
I am satisfied
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
