replacment carb
Re: replacment carb
so after testing I found the #1 cylinder spark plug was not firing tested the coil good now I have pulled the flywheel to check the points and condenser
farmboy186
Re: replacment carb
I'm curious what was your final jet set up that worked I'm going to do this soon
1974 John Deere 300 x2
1974 John Deere JDX4 Special x1
1975-77 John Deere 300 x4
1976 John Deere Cyclone x3
1978 John Deere Cyclone x1
1980 john Deere Spitfire
John Deere Sportfire x2
John Deere Trailfire x2
Re: replacment carb
200 and 25
Steven Rempel
Re: replacment carb
Any idea of how many mile with those setting? and what are you current thoughts on that set up?
wow just saw the dates on this lol
Re: replacment carb
^^ lol I was reading this earlier, thinking wow way to revive an old post
Re: replacment carb
I am going to be doing this swap to my 300 also. I have seen in other posts that the stock throttle lever has to be changed to get full stroke on the throttle. There is a You Tube video on the 300 with a mikuni conversion and he is utilizing the stock throttle lever and seems to be working fine. Just curious before I get into it what handlebar alteration I will need to do.
Re: replacment carb
I used the stock throttle works no problem
