ANOTHER SLED PROJECT... SPRINTFIRE #2
SS440-80
Real Name: Robert
Re: ANOTHER SLED PROJECT... SPRINTFIRE #2
Post by SS440-80 »
The rear light was gone. But I had an idea about using a LED-light.
So I bought a rear light with brake light. I glued it to a John Deere rear light glass. (same as old Polaris)
Mounted it on the rear of the seat.
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
SS440-80
Real Name: Robert
Post by SS440-80 »
The bushing for the steering was gone, just the collar left :(
Found a black piece of plastic and put in the lathe, a few minutes later I had a new good bushing and the steering was tight again :D
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
:needsnow: :needsnow: :needsnow:
Engine going back in
Don't have a airbox for this sled, but a cheap fiddy foam filter will have to doo.
But the foam is too compact, so it needs modifications...
Mounted
Brakepad and woodruff key to the "new" brakedisk
Brakes and speedometer drive mounted
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
Bumper was not pretty...
but after som black paint and a racing red tape, it looks much better
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
JDsledhoarder
Real Name: Jeremy
Post by JDsledhoarder »
Awesome work and dedication for all the custom parts. Can't wait to see our finished product. Keep up the great work
Jeremy
SS440-80
Real Name: Robert
Post by SS440-80 »
JDsledhoarder wrote:Awesome work and dedication for all the custom parts. Can't wait to see our finished product. Keep up the great work
Thank you Jeremy :beers; I hope that It will be ready before this winter :sled:
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
The exhaust on the sled was far from origiinal.
I think that the pipe was from a Ski-Doo, but I'm not sure. The muffler is some kind of motorcycle muffler I guess...
Muffler off
Modified the pipe holder to get a better angle on the pipe
test
Some cut and weld and the muffler is back on pipe, in a slightly different angle.
There are big ugly holes in the belly
But a piece of strong blue plastic in the right shape will do the trick
And exhaust fits perfect!
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
When I got the sled there was a P85 primary clutch on, but it was just just thrown on by previous owner because he did not have the original.
I made some detective work and found the guy who had the right clutch.
At first I was glad that I found the clutch... but after checking it out, I found out why it had been swapped out.
The dude had tried to pull it of with brute force and not with a clutch puller, so it was bent and bruised :wall:
I had two bad Comet 108, but with some luck and new parts I was sure that I could make one good clutch
Some new parts...
The rollers I got was for the wide rollers, so I machined out the spider some
And just to keep the right look, I put the JD clutch cover on :laugh:
It works :dance:
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
The sled looks a bit better now compared to when I got it :D
The only thing left to do is making a belt cover and the hood has to be painted.
But the sled is now tucked away in a shed while I am digging in to some other sled projects.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Awesome Work! It'll be a lot of fun, and satisfaction when you get it on the snow!
SS440-80
Real Name: Robert
Post by SS440-80 »
jep_800 wrote:Awesome Work! It'll be a lot of fun, and satisfaction when you get it on the snow!
Thanks!
I'm a bit nervous about the drive sprockets, if they will hold... :pray:
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
