Hi Everyone, I'm looking for a air box boot for a 1976 cyclone. It's the boot that goes from the box to the carb.
JD M 66450. Anyone have any ideas where or know anyone that may have one.? Any info would be great. Thanks
1976 JD Cyclone
1976 JD Cyclone
1974 JDX-4 SPECIAL
1976 CYCLONE 440
1983 LIQUIFIRE
1976 CYCLONE 440
1983 LIQUIFIRE
- Real Name: Jeremy
Re: 1976 JD Cyclone
Are you sure that is the correct part number? I don't see that part number listed for a cyclone.
Jeremy
Re: 1976 JD Cyclone
That was the number I got off the boot. I think it's correct. Do you have any ideas.? I'll try to post a pic of it.
1974 JDX-4 SPECIAL
1976 CYCLONE 440
1983 LIQUIFIRE
1976 CYCLONE 440
1983 LIQUIFIRE
Re: 1976 JD Cyclone
This is the boot and part number.
1974 JDX-4 SPECIAL
1976 CYCLONE 440
1983 LIQUIFIRE
1976 CYCLONE 440
1983 LIQUIFIRE
Re: 1976 JD Cyclone
Another pic of the other side.
1974 JDX-4 SPECIAL
1976 CYCLONE 440
1983 LIQUIFIRE
1976 CYCLONE 440
1983 LIQUIFIRE
Re: 1976 JD Cyclone
Does anyone out there have any ideas.?
1974 JDX-4 SPECIAL
1976 CYCLONE 440
1983 LIQUIFIRE
1976 CYCLONE 440
1983 LIQUIFIRE
Re: 1976 JD Cyclone
The part number that you're looking for is M66868.
- Real Name: Jeremy
Re: 1976 JD Cyclone
I agree with Don, I only come up with Part number M66868. Someone must have swapped some components on your machine. Will you be needing the part number that is correct to your machine or the part number that you currently have M66450?
Jeremy
Re: 1976 JD Cyclone
Often times the number stamped or casted into a part is just that, a casting number and not necessarily a part number.
