Throttle / Brake Blocks F/S
427cobra
Real Name: Eric
Post by 427cobra »
A pair of handle bar blocks.
The brake block is perfect and can be used as a throttle block on Liquifires. Throttle block is cracked but has the cable. Probably removed from a Trailfire.
$55
427cobra
Real Name: Eric
Re: Throttle / Brake Blocks F/S
Post by 427cobra »
Still have these...
427cobra
Real Name: Eric
Post by 427cobra »
Still have one perfect Brake/Throttle Block. Can be used as a brake block OR throttle block on the LF's. It can be used as a throttle block on sleds w/o the rev limiter as well...you will just have a hole where the switch would go.
Thanks!
$45
