81 Trailfire 440 Engine Recommendations
Hec In Omaha
Real Name: Hector
Post by Hec In Omaha »
Howdy all,
First let me say that I really appreciate this forum! There is a ton of great information here and great people willing to help others! :beers;
My story: I purchased a 81 Trailfire 440 back in Jan 2016. Odometer showed 1,400 miles on it. This is my first sled and knew I would be investing some time and money in getting it up to snuff. I am pretty good with tools and enjoy working on mechanical stuff. I only got to ride it for about 2 hours this season. Never got above 40 MPH for most of that time as I was given little kids rides. I did take it up to 50 MPH a couple of times for about 100 yds and then backed off. The weather here has not been conducive to snowmobiling so I have been reading old posts and have acquired a set of manuals in the mean time. The engine starts easy within 1 to 2 pulls. Once its warm it always starts in 1 pull. I did notice ,during the one time I got to ride it, that it has a lack of throttle response and was idling erratically. I thought that it was due to the K&N air cleaner the P.O. had installed. So I purchased the correct air box and installed it. It did run better with the airbox but the throttle response was still sluggish. So I backed out the air screw from one turn open to two turns open and the engine became very responsive and idled better. It also smoked a lot due the richer carb setting. So I figured I had a vacuum leak somewhere. I took out my can of carb cleaner and sprayed the intake manifold connection, carb connection and two crankshaft seals. Whala the PTO crankshaft seal is leaking. The engine tried to die while I was spraying the PTO crankshaft seal with the carb cleaner. So a reseal of this engine is required and I only hope I didn't damage anything during my 2 hours of putting around. :doh:
Compression Readings:
PTO Side Cylinder = 145 PSI
Mag Side Cylinder = 143 PSI.
Readings were taken with the engine stone cold outdoors with a 25 degree F reading with the throttle wide open Choke off. I checked the readings twice per cylinder using 4 pulls per cylinder.
My Plan for the engine:
1. Pull the engine, disassemble it and inspect everything. Replace what's needed and reseal and reinstall. This includes replacing the 3 O-rings on the crankshaft as well.
Questions
* Can I remove the primary clutch by using the OEM clutch bolt using the oil or grease technique? Or do I need to get a clutch removal tool?
* It looks like the flywheel can be removed using a steering wheel puller. I can fab up a flywheel holder myself with my MIG welder if needed.
* Any tips on the crankshaft O-ring replacement? I have found a source for the O-rings and not interested in the other style of seal. It appears that the O-rings will require a bit of stretching to install!
Tools I need to buy:
* CLUTCH ALIGNMENT TOOL JDM-81
Any other recommendations before I start? Anyone out there have the tools needed for sale?
Here is a pic of the engine as it is today
Thanks in advance!
Hec
1981 Trailfire 440
buckeyetrailfire
Real Name: Mark Elliott
Re: 81 Trailfire 440 Engine Recommendations
Post by buckeyetrailfire »
nice trailfire. just soak the orings in hot water for a couple of minutes and dry them off and slip them on to the crank.
Mark
1979 Trailfire 440
1980 Trailfire 340
1980 sportfire
Hec In Omaha
Real Name: Hector
Howdy All,
Long time no post. Well I finally started working on my 81 Trailfire 440 again. Motor is out and completely disassembled. Here is what is being replaced: Both Pistons and rings, wrist pins and rod bearings, crankshaft seals, crankshaft o-rings, outer crankshaft bearings and fan belt. It seams the motor sucked enough debris in through the outer bearings that they felt gravely. I can't believe this motor didn't have a melt down. I am sure glad I shut it down when I did because those crankshaft seals were in bad shape!
I have a couple of questions for the Engine/Mikuni Gurus!
1. I noticed a little bit of aluminum transfer on the center crankshaft bearings. The bearings feel fine. Should I replace them or just remove the aluminum transfer with Muriatic Acid and call it good. I spoke to a local motorcycle repair shop and he quoted my $300 to split the crankshaft and replace the bearings and press the crankshaft back together.
2. I don't think the carb on the motor is stock. Isn't the stock carb a Mikuni VM34? I looked up the dimensions on the VM34 and the opening of the carb, which the rubber boot stretches over , should be 58mm diameter. My carb's opening diameter is 57.50mm or 2.264"in diameter. So maybe its a VM-34? If anyone has a good used carb for a Trailfire 440 please PM me. By the way what are the differences between the 340 and 440 carbs?
Pics
What Carb is this?
What Carb is this?
Stamp Reads G8 71
Stamp Reads G8 71
1981 Trailfire 440
