Trailfire 440 engine issues
flacker36
Post by flacker36 »
I have a trailfire 440 that has engine issues. The engine has been rebuilt from top to bottom. It starts fine, but the idle is real low. As it warms up the idle goes way up. Then after riding, you turn off the key or kill switch & it wants keep running but like on only one cylinder. Any helo would be great.
Joe
Hec In Omaha
Real Name: Hector
Re: Trailfire 440 engine issues
Post by Hec In Omaha »
I would check the wiring on the 5 terminal plug you had to disconnect to pull the engine. You mentioned that the engine was redone from top to bottom so I am assuming the Flywheel and stator plate was removed. If so, you had to remove 3 wires from the 5 terminal plug in order to remove the stator plate etc.. I hope you recorded how those 3 wires were oriented so that they go back in the same place in the plug.
That's my wild guess
Hec
1981 Trailfire 440
flacker36
Post by flacker36 »
Ok, thanks I will check that.
