1974 jd 300 help please
Kent32
Real Name: Adam kent
Post by Kent32 »
I’m looking for some help with my sled. I have a 1974 John Deere 300 with the Kohler k295-2ax engine
and the walbro WDB-31 carb. The carb has stoped pulling gas from the tank. I’m assuming that the internal fuel pump/gasket is bad and the carb needs to be rebuilt. However I can not find a rebuild kit anywhere. My question is - Is there a different carb I can replace this one with where I can get rebuild kits more easy and if not, what are my options? Thanks again for your time and experience!
~Adam :popcorn:
big jeff
Real Name: jeff
Re: 1974 jd 300 help please
Post by big jeff »
Adam look back in past posts all my info is there about replacing tthe carb on my 74 300
big jeff
Real Name: jeff
Post by big jeff »
Kent32
Post by Kent32 »
Big Jeff
Thanks a lot I really appreciate that info. Did you ever figure out the jetting and get it to run after it warmed up ?
big jeff
Real Name: jeff
Post by big jeff »
still running the same jets runs great
