81 Trailfire 440 Hard to Pull
Hey Guys, recently got back into the JD sled game and picked up a cherry 81 TF 440. Runs good but needs some adjustment (Drain gas tank, rebuild fuel pump, rebuild card, fuel lines, chaincase, clean and rebuild clutch etc. Going to run through the winter here in NE Ohio and have fun with kids, but noticed from my TFs I had years back that this seems "heavier" to pull over - enter the dad jokes below... Compression is 150 in both cylinders, pull rope and guide tube seem aligned (not bent), I haven't tore into the recoil yet, but any thoughts? Clutch out of adjustment, belt too tight? Something else I should look at?
- Platinum_2
- Real Name: Gary
Re: 81 Trailfire 440 Hard to Pull
Every sled has its quirks. If it starts easily and runs good, I wouldn't even bother investigating unless it becomes a problem. Maybe hit up the weight room?
1981 Liquifire
1980 Sportfire
1980 Sportfire
Haha knew that was coming...
Agreed Plat thanks
It's very important witch 2-stroke oil you use.
Some oils get very "sticky" and almost glue the pistons to the cylinder walls. They don't have to be bad oils, but makes the motor hard to pull when cold. And both mineral- and synthetic- oils can be like that.
I don't know what brands you use in the US, but someone here on the forum should be able to name a good oil that don't leave a sticky film.
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
I'd switch the crank seals if you're unsure of the last time they were freshened. I bought an 82 LX many years ago with very few miles on the clock and it burned down because the seals were faulty due to the sitting around disease.
Super great adviceAirborneX4Special wrote: ↑Fri Dec 18, 2020 2:40 pm I'd switch the crank seals if you're unsure of the last time they were freshened. I bought an 82 LX many years ago with very few miles on the clock and it burned down because the seals were faulty due to the sitting around disease.
But changing the crankseals won't make it easier to revolve the engine...
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
- Platinum_2
- Real Name: Gary
.....but hitting up the weight room will!
1981 Liquifire
1980 Sportfire
1980 Sportfire
Just trying to help out from the school of hard knocks!SS440-80 wrote: ↑Fri Dec 18, 2020 5:32 pmSuper great adviceAirborneX4Special wrote: ↑Fri Dec 18, 2020 2:40 pm I'd switch the crank seals if you're unsure of the last time they were freshened. I bought an 82 LX many years ago with very few miles on the clock and it burned down because the seals were faulty due to the sitting around disease.![]()
Changing crank seals is one of the best things you can do on a old twostroker to keep it alive for a long time
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
- Platinum_2
- Real Name: Gary
Yes, it should be standard procedure when resurrecting a vintage sled. Especially those with Kawasaki engines as they seem to be the most prone to failure.
1981 Liquifire
1980 Sportfire
1980 Sportfire
Thanks everyone, going to run it through the winter and pull the kids around on a sled. Everything seems to be in good working order and running just hard to pull. Plat, I should be jacked come summertime when I decide to replace crank seals and top end gasket seals.
Merry Christmas everyone!
