Wanted: 82 sportfire exhaust shroud
Charliev65
- Real Name: Charlie Vierke
Looking for the engine exhaust shroud. Piece between cylinders and header pipe.
Re: Wanted: 82 sportfire exhaust shroud
I have them
Charliev65
Awesome! Good condition? What’s your price?
Where’s shipping to ?
Charliev65
Belvidere IL 61008
$30 shipped
Charliev65
Ok sounds good, you have a picture? How do you want me to pay, through PayPal?
Yes my PayPal is smit_dustin@yahoo.com
I have a couple , I’ll send the best one
Charliev65
How about suspension parts? Bracket for the bottom two idlers and a rear arm that has the mounting tabs for idlers wheels? I’m trying to install newer rubber track from a newer sportfire.
Yes I do have brackets and one rear arm left but the shaft is tight in it
Charliev65
I would need one bracket, and is there any chance of getting that shaft out? What would you want price wise and how about a good shock?
Do you need the front idler blocks too? Those are extra on a all rubber track .
I usually get $100 for all 4 brackets/blocks.
$30 on Arm as is, not going to mess with it
I would have a Good trailfire arm for $50 you’d have Weld tabs on for the idlers, ive had them done before.
Charliev65
This is what I have, the painted one is for old cleated track which doesn’t fit of course. The other fits but is missing the one bracket and bottom idler. I don’t know what it came out of, assuming it was newer sport or liquid and not sure why it doesn’t have the idlers on rear frame. My 82 sport has the idlers on rear frame.
To me it looks like the other is a trailfire skid with the front arm added along with the three wheels. They probably didn’t put the four wheel on cause they didn’t know how. Is the other side just held on by bolt ?
Charliev65
Well the bracket that would hold the missing bottom idler is broke off, I stuck a bolt in it to hold together for a test fit.
