Looking for a crankcase for a 74 CCW 340 - my case is warped.
Wanted: 74 CCW 340 Crankcase
1973 JDX8 (maybe parts sled)
1974 JD400
1975 JD800
1982 Trailfire LX 440
1974 JD400
1975 JD800
Re: Wanted: 74 CCW 340 Crankcase
Still looking
1974 JD400
1975 JD800
1974 JD400
1975 JD800
- ihengineer76
- Real Name: Tom Rehberg
May I ask how you determined it was warped? Generally, die cast aluminum will crack before it would warp.
1975 340/S - I-500 raced sled
Sorry I somehow missed this - sled when I got it had an extra oily mess at this one spot on the front of the case (not from exhaust manifold) resealed engine with Yamabond (a light coat) let it cure for a week and re assembled and it kept spitting out in that same spot. Took it apart again and with a straight edge it isn't flat. At this point I don't want to put it together again only to find it not work, that's where I was hoping to find a case.
So far it's been extremely difficult to find another case - locally everyone has the older KEC 340 motor (pre 74). Haven't had any luck online etc. What I need is the KEC 340/5 case.
1974 JD400
1975 JD800
1974 JD400
1975 JD800
- ihengineer76
There is one listed for sale on Facebook Marketplace in Elk River, MN.
Ended up getting a hold of John Schavemaker on facebook and luckily he had one squirreled away. Excited to finally get the sled back together again.
1974 JD400
1975 JD800
1974 JD400
1975 JD800
