John Deere 600
John Deere 600
I have zero experience with John Deere sleds but have the opportunity to get a 600 for a good deal. I am trying to figure out the year to determine how hard it will be to find seals, gaskets, and the parts ill need to get it running. I was told the serial number is 00515m. Could anyone tell me what year it is based on that? Also, if anyone has information on seals and parts for these 600's let me know. Thanks!
Re: John Deere 600
It should be a 72-75. Here is a link for parts. You will need to put the info in the parts search pull downs. Just put in a 74 for the year. Not sure if the VIN plate is the same as the 76 and up sleds. The plate may show a manufacture date in a month and year. So if the plate says 7-74, it is a 75 model year.
https://newbreedparts.com/
If they do not have what you are looking for, E Bay is another option. Just put in John Deere 600 in the search.
Dan
1981 Liquifire
1984 Trailfire LX
2018 Ski Doo Summit Sport
1981 Liquifire
1984 Trailfire LX
Re: John Deere 600
Looks like there were 2 different engines for the 600, is that correct? both look to be 440's but different manufacturers. Is one better than the other?
Re: John Deere 600
Welcome Cooper,
None of the serial numbers start with 0, the first year of sleds stared with 11,000, so they may have mis-read the first digit. The engines are slightly different models, and there were only minor updates between them.
Re: John Deere 600
Can you show me the fuel line routing for it? Or where I may find the fuel line routing? Thanks
