Walbro WDB-31
dikeman
Real Name: Jeff Dikeman
Walbro WDB-31
Post by dikeman »
I'm looking for a high needle for my carb, thus far no luck in my internet search.
Any help would be appreciated.
Re: Walbro WDB-31
I don't know much about that particular model carb, but many used the same needles... Would this be the correct one, or does it require a special needle?
https://www.ebay.com/itm/125678311984?i ... R6j1mKy9Yw
Re: Walbro WDB-31
Actually, for the carb you list, which I assume is for a JD 300, it definitely is the correct high speed needle. The parts manual shows AM 53093, which is the number on the eBay listing I attached.
dikeman
Re: Walbro WDB-31
Post by dikeman »
This carb has a needle on the top which I believe is the AM 53093. Then on the left side of the carb there are two ports, one marked with an L that has another needle in it and beside it a port marked with an H. These port has no needle but certainly appears to have a hole going into the carb. Did this carb originally have three needles or did Walbro use the body for multiple configurations?
Re: Walbro WDB-31
Two needles on these models. The one on the top is the high speed adjustment. The one on the side is the idle mixture.
