Lubricating slide suspension shaft
sserven
Real Name: Sam Serven
Post by sserven »
What does everyone use to lubricate the aluminum shafts in the suspension of a 78.spitfire? I've got mine all out and they had some old grease on them when I took them out. Was wondering if I should use anti seize, grease or oil for lube when I put them all back together. Sled won't see a lot of miles here in Illinois so it will be sitting most of it's life.
snowmoer
Real Name: Dan
Re: Lubricating slide suspension shaft
Post by snowmoer »
Welcome!
I always just pulled them every year, clean off the old grease, and coat them with fresh waterproof grease. Then put them back in. Good thing you are doing this. They are a real pain to get out if they were not greased every year! If not done, then the suspension arm pivots on the bolt that goes through the tunnel. Not on the shaft.
Dan
1981 Liquifire
1984 Trailfire LX
2018 Ski Doo Summit Sport
sserven
Post by sserven »
Thanks for the reply. What do you use for water proof grease?
snowmoer
Real Name: Dan
Post by snowmoer »
Back in the 80's when a Deere was my main sled, I used marine grease that you would use on boat trailer bearings. Now I just use the Ski Doo waterproof suspension grease because that is what is in my snowmobile grease gun. You can still use the boat grease. You should be able to find it at Wal Mart or any auto parts store.
Dan
1981 Liquifire
1984 Trailfire LX
