My sled wants to run lean unless I have the idle 3.5 full turns out ar which point it runs great. This seems excessive. Rebuilt carb with good kit, metering arm at 20 thou, rebuilt engine. Is this normal or is something wrong
What is the procedure for adjusting theese guys.
John deere 400 carb setting
Re: John deere 400 carb setting
What model carb are working with?
Yes, that is excessive. Are you driving the sled around? What overall performance are you seeing?
