1979 John Deere Trailfire 440
liquifire_freak
i nned to know the right belt number for my sled probally LaMans or Dayco belts THANKS ALOT EVERYONE hope you can help
On my 1980 Trailfire I use Dayco Ultimax belts...#125-4616
They've worked great for me and i have yet to burn one up!
Brad
Brad
liquifire_freak
is that the actual number? im not really furmilliar with that number im used to like Dayco Max 1080 or something like that well jope to hear from you soon
Liquifire,
The belts that i use for my trialfire are nos...i found on ebay a bunch of belts being sold together and got 10 of them in one shot...they are all still in the packaging and even on the package they say dayco ultimax 125-4616...i know the 1080 will work also, thats just what i use! Hope this helps you a little bit!
Brad
Brad
grasscutter97
Don't take this wrong way dude, but you seriously need to read the posts that people send to your questions.
You've asked this belt question a number of times, in different forums, and 4 or 5 pages of posts has resulted, and still you don't know the belt you need?
Let me sum it up for you...(I am quoting harleysportster from an earlier post)
<<<<There are 2 Dayco belts that will work. The 1080 is slightly smaller than the original JD M66345 but works for some, but others are using the 1078. They both show up in different vendors books.
Here are the belt measurements:
M66345: 47.3 inch (+- .12) x 1 1/4 inch
1080: 46-3/16 inch x 1-1/4 inch (3/16 =.018)
1078: 46-5/8 inch x 1- 1/4 (5/8=.625)
The belt measurements are nominal which means close but not actual>>>>
Hope that helps, and hope you get the correct belt for many miles on the snow.
