liquifire exhaust pipe
has anyone ever cut open the pipe on an 81 liquifire? it has a headpipe like a regular tuned pipe, a diffuser cone, and then the belly extends all the way to the end of the pipe with no converging section. im thinking that there must be a converging section as well as some kind of muffler inside the outer belly. went for a brief ride today and the pipe was glowing red about 6 inches in front of where the stinger exits. im thinking i may have a rusted muffler inside the pipe that is causing this. i want to cut the pipe open to investigate but thought i would check here first. does anyone know how this pipe is designed, what i should expect inside, and where the safest place is to cut the pipe open. btw i know my jetting is a little lean. thanks in advance for your expertise and advise.
I would say that mr. or mrs. mouse has been up your pipe. Some times there are NOS mufflers on Ebay, if you don't want to cut yours & reweld it
A quit a few years ago a freind of mine stored his sled in his enclosed pourch where he also fed his dogs, that next winter he pulled the sled outside & when he pulled it over the engine only turned about 1/4 turn & locked up, after removing the muffler & y pipe we found out that the mice filled the muffler, the y pipe & the cylinder full of dog food. They must have thought it was going to be a long winter.....
cut the pipe open today and it was as clean as a whistle. at least i know how it works now. it was glowing because of a lean condition. (note to self--dont run sled without air box, even for a short while) the glow was directly adjacent to the outlet in the baffle. i took notes and pictures in case anyone else is curious what is going on inside there.
gwerty: That would be great if you would post the photos, always wondered what they looked like inside??? THANKS........Guy
i tried last night but the smallest i could shrink the photo was from 1.19 mb down to 270 kb and the forum wouldnt accept it. can anyone tell me how to shrink these photos more, because i have this problem all the time.
I am far from an expert. I just continue to shrink the shrunk ones til I get the size the form will take, 200KB if I remember right. Matt, JDMatt, will be able to help you. He is great on this stuff.
Matt: Can you help out?? THANKS!!
swedetrail
You need to change file type on the pictures, most cameras save in BMP but best for web is JPEG. A 14Mb BMP picture shrink to 80kb when saved in JPEG format.
/C
/C
i hope this helps the members. view of pipe body and baffle from stinger end. note- 60 holes 3/16 diameter in a 2 inch long band is all your exhaust passes through. so i drilled a few more just for good measure
same view looking inside baffle
view of converging section looking from engine side
view inside pipe end note the bung that the baffle fits tightly around
this is how it all goes together
this is a before picture. you are all now my witness. now i have to get it done
Gwerty: THANKS for great photos.
RICH: Which part had a tendency to come loose and effect performance on the 80LF as you have mentioned????
