Timing
Deleted User
Timing
Post by Deleted User »
Which way do you turn the stater to advance timing? 1980 Liquifire
speedy295
Timing
Post by speedy295 »
opposite the way the engine turns. I don't want to be mean but i can't belive anybody should have to ask this.
guitardude081
Real Name: Jack Durand
Timing
Post by guitardude081 »
Turn it 6 degrees counter clockwise. Use a timing gauge to help with this. You can get it close by eyeballing it, but it may not run right.
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
Deleted User
Timing
Thanks, Thats what I thought, Just wanted to make sure
ProJd69
Timing
Post by ProJd69 »
To speedy295: Thats what this site is about ...To get help/answers. So if you have a comment like that (not to be mean) please keep it to you self. SORRY I just found it to be Inappropiate.
JDFanPa
Timing
Post by JDFanPa »
Ditto what projd said.................maybe someday speedy will have a question
That Girl Racing
Real Name: Peter
Timing
Post by That Girl Racing »
Here is a few timing tips. Advancing the timing gives the sled more torque out of the hole and less power on top. Retarding it does the opposite. Advancing also raises the sleds shift RPM. Retarding , the opposite. The same goes for compression. More compression, more torque down low and less peak power. Lower compression the opposite. If the motor detonates when timing is advanced you lose power and could burn it down. Liquifire stators do not really have that much adjustment in them. Moving the trigger ring will not make that much of a difference unless the motor detonates. Peter
sporty440
Timing
Post by sporty440 »
Im just glad that we are finally spelling the word "timing" correctly. ahahahahah
