Does anyone have a trick to getting carb slides on the cables without the whole damn thing flying across the shop? I've tried for 2 hours now, and I've never had THIS much trouble.
~Jack
LF carb woes
- guitardude081
- Real Name: Jack Durand
LF carb woes
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
LF carb woes
Screw the carb cap onto the cable, install the spring into the cap, compress the spring with 2 finger of the hand your holding the cap in, & with the other hand install the throttle valve/slide onto the cable so it slides into the retaining slot, then install the jet needle into the slide
( Note if you carb has the little nylon washer that goes under the E-ring on the jet needle then install that before the jet needle ) then install the little plate that keeps the jet needle from coming out of the slide, then release the spring into the slide, Remember practice makes perfect.
Ken
Ken
- guitardude081
LF carb woes
Damn, that's the only thing I didn't try. I will try that after the decals, tank and seat go on tonite. I will have a running sled by next week when the 108-c gets here.
~Jack
~Jack
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
ProJd69
LF carb woes
Hey guitardude81 give me a ring or PM if having prob's I"ll stop over and help.
