Cleaning plastic gas tanks
HoosierDeereMan
Real Name: Troy Miley
Post by HoosierDeereMan »
I was wondering if anyone has had any luck cleaning the outsides of the cream colored plastic gas tanks. I have the 6 1/2 gallon plastic front mount tank that is very grungy and stained looking. Is there a plastic polish or some other means of cleaning these so they look new again?
b00stinGTP
Post by b00stinGTP »
I wiped mine down with a rag soaked in gas. The gas helped get all the grease off, then I wiped it down with some alchohol that I was using to prep for painting the engine compartment. The tank is clean, but still is yellowish looking, but I dont think any cleaners will get rid of the age.
Sleds I own
1974 John Deere JDX8. (SOLD)
1975 John Deere JDX4. (SOLD)
1977 John Deere Liquifire 440. (SOLD)
1978 John Deere Cyclone 340. (SOLD)
1980 John Deere Liquifire. (SOLD)
1983 John Deere Liquifire.
T-roy, try this. If you have a Walmart handy ( or AutoZone) go to the automotive department and ask for "Yellow B-Gone". Sometimes it comes in spray and sometimes it has to be hand rubbed. Don
johndeere96
Post by johndeere96 »
Hello
I found a gentle trick to clean fragile plastic parts.
Mix a solution of liquid car wash soap and tri sodium phosphate powder (TSP) in water.
TSP is a common cleaner available at your local hardware store.
Leave the parts immersed in the solution for several days, then scrub with a nylon finger brush.
A good rinse with cold water removes the residue.
Be patient, it will take a while to release the stubborn stains. Agitate the parts to move the solution around.
I used this method to clean a badly stained oil tank on my Liquifire Project.
I have used Don's option of Yellow B Gone for a convertable top rear window and it works as well too.
JohnDeere96
