I HAVE A 79' T/F AND NEED THE SHOCK THAT IS UNDER THE SEAT.
ANY INFO ON OTHER TYPE THAT WILL WORK OR IF ANY BODY HAS FAB SOMETHING UP. I REALY DON'T WANT TO CHANG THAT MUCH BECAUSE EVERY THING BUT THE TRACK IS ORIGINAL.
B)
THANKS,
B.IRVIN
TRAILFIRE SHOCKS
TRAILFIRE SHOCKS
My first question would be is it a replacement track?? or a different track & maybe suspension from another brand sled??? we need more info on that????B.IRVIN wrote: I REALY DON'T WANT TO CHANG THAT MUCH BECAUSE EVERY THING BUT THE TRACK IS ORIGINAL.
B)
THANKS,
B.IRVIN
There probably isn't any NOS suspension shocks out there & finding a good used one might not be easy either, But there are replacement shocks that can be purchased from
MN Vintage snowmobile, Kimpex, or Dennis Kurk & other aftermarket suppliers you just need to know what you ID is of the bolt holes, compressed length, & extended length..
You might first CK with the JD East Beach Whse. ( Joe " Have Trailer Will Haul " Rainville ) to see if he has a NOS AM54745 shock.
TRAILFIRE SHOCKS
B, I feel pretty comfortable that the track/suspension is stock. Dad or Uncle John wouldn't have changed it. UD
TRAILFIRE SHOCKS
YES, IT IS A REPLACEMENT TRACK. ALL THE SUSP IS STILL ORG.
THE SIZE OF THE SHOCK IS 10.20 COMP. AND 16.50 EXP.
B.IRVIN
B.IRVIN
TRAILFIRE SHOCKS
RICH,
YES I DID GET THE INFO AND E-MAILED YOU BACK. I AM GOING TO SEND YOU A MONEY ORDER.
IF THE SHOCK IS OK JUST TELL ME HOW MUCH AND I WILL DO THE SAME FOR THAT.
NOW FOR THE SLED YOU ARE PARTING OUT WHAT IS MISSING?
MY SLED IS PRETTY CLEAN NOW BUT I COULD ALWAYS USE BACK UPS.
THANKS,
B.IRVIN
THANKS,
B.IRVIN
TRAILFIRE SHOCKS
IRVIN,
I VE GOT A 79 TRAILFIRE I VE GOT THE ORG SHOCK THAT CAME ON THE SLEDPART NO. AM 54745 MADE BY GABRIEL WITH MEASUREMENTS OF FROM CENTER TO CENTER ON THE BUSHINGS 11 7/8 OPEN,8 3/8 CLOSED
I TOO AM LOOKING FOR A SHOCK LOOKING FOR A GAS THOUGHT
DAVE
DAVE
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
06 SKI-DOO MACH Z 1000CC
79 TRAILFIRE 440
79 KAWI INVADER 440
TRAILFIRE SHOCKS
THANKS DAVE
IF YOU WANT TO SPEND THE MONEY YOU CAN GET ONE FROM FOX THAT WILL FIT.
I WOULD DO THAT BUT I CAN'T JUSTIFIE SPENDING $700+ ON ONE SHOCK.
HAVE A GREAT DAY
B.IRVIN
HAVE A GREAT DAY
B.IRVIN
TRAILFIRE SHOCKS
IRVIN
$85.00 GAS SHOCK MADE TO FIT TRAILFIRE ,AFTER I BUY ONE ILL TELL YOU WHERE TO GET THEM HE ONLY HAS 3 LEFT.
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
79 TRAILFIRE 440
79 KAWI INVADER 440
TRAILFIRE SHOCKS
OK
THAT SOUNDS PRETTY GOOD.
TELL ME HOW IT TURNS OUT
THANKS-
B.IRVIN
THANKS-
B.IRVIN
