Dual carbs on a Cyclone
Greenxcracer76
I want to put dual carbs on my 76 440 Cyclone. Where do I start as far as jetting? Same as the Liquifire? How about clutching? Thanks.
Greenxcracer76,
Do you have everything that is necessary for the conversion:
dual carb manifold
dual carbs
dual fuel pump
dual carb airbox
twin throttle cable setup
twin choke cable setup
I would use the 440 liquifire carb specs as a starting point, found in the FAQ section.
The cyclone clutch will work, but the liquifire primary clutch has different weights in it, and a black spring. The liquifire clutch setup as a clutch engagement of 4100-4300 rpm, verses 3500-3700 rpm of the cyclone. The secondary is the same. The gear ratio is the same also.
dual carb manifold
dual carbs
dual fuel pump
dual carb airbox
Greenxcracer76
Harley, thanks for the help. I have all the pieces just looking for my starting point. Thanks again. Mike
