340/S clutch help
8ho
340/S clutch help
Post by 8ho »
if someone with a manual for a 340/s I would like the center to center distance for the clutchs.Had to pull the motor and I don't think I got it right and I don't have the manual thank you steve went to albright shores sat. and 3 DNR clowns drove thought the pits on sled making out like they were looking for someone I guess not many people fishing so they need the $$$ from us sleder
kioritz
340/S clutch help
Post by kioritz »
From edge of driven clutch sheave to the edge of drive clutch sheave should be 4.30" according to the 340/S service textbook.
8ho
340/S clutch help
Post by 8ho »
thank you for the info. it said to take the measurement from between the clutchs and not the center of the shafts. I will give this a try thank you steve
8ho
340/S clutch help
Post by 8ho »
the center to center measurement will help the side to side is fine I don't smoke the belt.It just is not running up in the clucth it is about 3/4 of and inch from the top I droped the top gear from a19 to a 16 the merc. just get out of the corners alittle faster then me. Got beat at A.S. last weekend by 6inch
8ho
340/S clutch help
Post by 8ho »
I think it is close that is why I changed the gears will see if this work sat.Going to lucky thumb this saturday.went there two weeks ago for the frist time and all I can say is people up ther like to watch sled races.Because that place was packed
