I really like he look of that little Liquid engine....
How does it stand, powervise against the other deeres??
Is it a good engine? It was never in any Kawasaki sled, or ?
Thanks!
/Magnus
The Invader uses the same exact pistons as the Snowfire and Spitfire. They will work in a Sprintfire, BUT, the Sprint was a cast bore. The Invader pistons you installed were designed for a chrome bore. They will work but the life expectency is SHORT, expect 400 miles MAX until meltdown. So enjoy your rebuild because it is short lived. Al's gave you bad info. I have a run of Sprint pistons being made they will be available in late June or early July.JDDDeere wrote: HI Magnus...
I am restoring one (complete overhaul... new crank, pistons, rings, seals, you name it).? For what is worth, iwasa having a lot of difficulty findin parts at all the usual sources... that said, I was informed by someone at Als Snowmobile that he KAwi 340 Invader (78-79) is th esam eengine... not sure how that helps you???
Since them, I've gotten a few engine parts that are speced to the invader (such as pistons) and they appear to be an exact fit/replica....
Anyway... like I said... for whatever it s worth.
Hoping to hear this thing run sometime this winter...
Dan
See above post regarding the pistons. I have gasket sets available as well as any individual gaskets you might need. Shipping to Sweden isnt a problem.swedefire wrote: Wont the trail/spit pistons fit the Sprint then aswell??
Also, were do you guys get the headgaskets?? I have all except the two that seals the compression off..., not so keen on reusing them....
Thanks!
/Magnus
The Invader used the same pistons in all years, they interchange with the Snowfire, Spitfire, and Trailfire. So any of these applications are the same for all model years, BUT - I would not suggest installing these pistons. I can attest personally to the miles until failure as can Ed Poets. 400 miles and your back to square one.jdsledwheelman wrote: Is there a certain year of Invader you order the pistons for, or does it work from all years of Invader? Just doing my home work before I ever get in to a rebuild situation.
thanks Nick![]()
The Invader rings are not for a cast bore, they are for a chrome bore. They will wear out in no time. Cast rings are different than chrome rings, it's no different than installing cast rings in a chrome bore. The rings will destroy the bore in no time.JDT wrote: So why not use the invader pistons with the correct rings for cast bore?
