please help me figure out the year lol cant seem to figure it out
what year is this sled?
Liquifirefreak. You,re Indy is most likly a 91,but maybe a 92.
Definately a 92. That was the only year the 500 SP Fuely had pink graphics. The 93 was black with some turqouise/blue/aqua graphics.
Peter from Roblin, Manitoba
i am getting this sled soon and it has no spark was they're any electric problems with these sleds? im thinking a new coil or cdi just wanting to know if they were ever any real problems with these sleds but just waondering and one last question are they fully fuel injected or whats the deal with that?> well thanks everybody for your help im very thankful and everybody take it easy
Like Rich says, a good battery is essential. The 92-94 EFI Polaris sleds used a very small YB9A-A battery and you were lucky to get 2 seasons out of them. So make sure the battery is up to snuff. The most troublesome thing on the fuelies were bad electrical connections. I'd pull apart every connector and clean the contacts fully, then apply some dielectric grease to all of them before reconnecting. Hopefully, the EFI brainbox is OK......but they sometimes crapped out and a replacement is expensive. A fairly common problem on the 92 Indy 500's (not just the EFI's, but the carb jobs too) was the exciter coil on the stator plate. I sorta doubt this is the problem though because even when they went bad, they'd usually still give spark until the engine warmed up and then quit......but I have seen a couple that went out totally. If yours is bad, you can replace just the coil without buying the entire stator plate. Regarding the CDI box, they are generally bullet proof on the Indy 500's....so I doubt it's the problem, but you never know. The nice thing about it is that the same CDI is used on so many Indy 500's, you're sure to know someone who can lend you one from his sled to try.
Last edited by Liquifire 4/6 on Wed Jul 09, 2008 10:25 pm, edited 1 time in total.
so is there a carb on this sled or is it completely fuel injected? and are these indys hard to work on? well just wondering im getting the sled tomorow so ill let you know what i figure out!! does anybody have any parts they would be willing to sell? Thanks Everyone for your time and help im sure they're be more questions to come!!!
owe i forgot to tell everyone i have deere sleds and parts i would trade for some parts for this indy i just want to get the problem figured out asap
If it's a stock original sled, it does not have carbs. Instead, it uses dual EFI throttle bodies (which to some extent resemble carbs, but are vastly different). However, it is entirely possible that during the last 16 years, someone may have changed it over to carbs.....I've seen this lots when people have EFI brainbox probs and aren't keen on paying nearly a grand for a new box. I don't have any EFI parts left, but if your exciter coil is bad, I might have one kicking around ......just not real sure. Are they hard to work on? Yes, without the proper test equipment, your pretty much buggered. But you local Polaris dealer will likely be glad to work on it for $75.00/hour or so. I hope you are getting the sled real cheap as I'm betting you are purchasing a headache. Good luck!liquifire_freak wrote:so is there a carb on this sled or is it completely fuel injected?
Last edited by Liquifire 4/6 on Thu Jul 10, 2008 12:13 am, edited 1 time in total.
i got the sled today its in good shape. i wish it ran lol well i need to start narrowing down things, im gunna get to it asap if anyone has any suggestions please suggest them lol well need any tips and all the info everyone know because i dont know a thing about these snowmobiles. ONE lat question when these sleds run right are they good reliable sleds? this sled has 4100 miles on it is that alot or what? Well thanks everyone and you'll hear from me soon
