Cleaning engine
JDman21
Cleaning engine
Post by JDman21 »
I have an engine torn apart and want to clean the inside of the crankcase and everything. What is the best thing to use? Also how can I clean up the outside of the engine like the outside of the cylinders? How can I make it shiny again?
flames4555
Cleaning engine
Post by flames4555 »
I use a combination of methods on the outside of the motor, depending on the degree of sludge .
I start with a Gunk type engine cleaner and a good scrub brush to get all of the heavy stuff off. Next I take a scotch brite pad and some WD-40 and give the block a good scrub down. After all of the above is completely cleaned off I use a buffing pad on a cordless drill and a good metal polish ,such as Mothers or Blue Majic. Any of the rough area 's are done by hand . It all takes a while ,and a lot of rubbing ,but is pretty rewarding when finished .
Here a picture of the 440 I just finished for my cyclone.
Kevin
76 cyclone 440 (dual carbs)
69 Arctic cat panther p22j
1982 kawasaki indtruder
1980 kawasaki 4/6
74 cheetah 440
1967 buick wildcat convertible
Cleaning engine
flames4555,
the engine looks great. I would suggest spraying a clear lacuer over the polished aluminum, otherwise it will corrode later.
flames4555
Cleaning engine
thanks for the advice Harley ,
I do automotive detailing during the summer on the side and in the winter I
re-polish my sleds to keep in practice :lol: . You are correct a polish job can be short lived ,but with the lack of snow recently and the warm temperatures I have been doing a lot of polishing .
Kevin
Kevin
1980 kawasaki 4/6
74 cheetah 440
flames4555
Cleaning engine
Thanks for the heads up I will turn the hose as you mentioned above . When I started the resoration the sled didn't have the air box or the tube and I was just following the pictures in the John Deere service and illustrated parts books I have . I'm a definately going to ride it and i'm almost ready to take it off the table just need one ingredient....SNOW.....
Is there a publication where all of the service bullitens for my cyclone are
located , I would be interested in making sure my sled if up to date and set up properly.
I also want to thank you all of all of your insight. This is my first deere resortation and this site has been a great resource . I can 't wait to finish this one so i can start looking for a Liqifire of the same vintage .
thanks again,
Kevin
Kevin
1980 kawasaki 4/6
74 cheetah 440
Cleaning engine
Kevin, how many toothbrushes did you go through on that one???
Most of the really nice engine restorations I've seen at shows came from being bead-blasted. I haven't tried it yet but I'm planning to.
JDXsand00s
Cleaning engine
Post by JDXsand00s »
all of my engine have been sandblasted, crankcase, jugs, heads, and fan shroud. then i spray the crankcase with carb clean to get excess sand out of the holes and i hone the jugs and carb clean them. they look awesome when done and it probably is a lot easier than the manual method previously stated if you have access to a blasted.
flames4555
Cleaning engine
When through a couple a couple of tooth brushes , lots of rags and most of all elbow greese . The key to the shine is the buffing pad and a cordless drill with blue majic polish. The picture makes it look a real good , but I wouldn't call is show quality. Though my wife says if I keep polishing and painting thing I'll be afraid to ride it when I'm done . My hope is to have it complete before the show next month in New Hampshire.
I 'm sure the bead blasting would speed up the process and give a much better final product , I hope to do the same on a sled in the future. When I go to this extent if will seriously consider clear coating to keep the corrision from comming back as Harley suggested above .
Kevin
Kevin
1980 kawasaki 4/6
74 cheetah 440
Cleaning engine
Kevin, I'm looking forward to seeing it in NH...
