Any of you guy's have any Idea why there is such a large ( 8" Dia. ) brake disc on the 340/S's, ( whereas every sled even the Dator, after that had a 7" dia) could this be something that Deere used from some other Mfg. or from another source?? Like Maybe Kelsey/ Hays being that is where they got the juice brake from?? Rich If the part number starts with a AM rather than a M what does that mean??
ED or Rich, anyone
ED or Rich, anyone
ED or Rich, anyone
Anyone thinking about reproducing the disc????? DA
ED or Rich, anyone
Iused the disc from And old cat,but you have to drill the rivet out and use the bolt , the jackshafts are different
ED or Rich, anyone
Was the jackshaft diameter the same? Any pictures?
ED or Rich, anyone
I used the disk from the cat and the center from the 340/s. The cat disk is the same as the JD but the shaft size was to small. On the cat the disk is bolted on so I just drilled the rivet out of the 340 and used that center. Because my disk was very pited and rusty. I think it was from a mid 70's cat got it at the junk yard
ED or Rich, anyone
Thanks! Makes sense. DA
