Liquifire elec start
- JDXspec
- Real Name: Dustin
Heres a question for you guys. I would like to put a elec start kit on my 83 LF it has the ring gear and housing to accept this. I acquired a 1980 Trailfire (best for parts) with elec start, can the kit be converted to fit my LF?. JDparts does not show a elec start kit for the LF and I did notice a serial # break for the trailfires. Wondering if anyone has a LF with a starter of has installed one. I remember someone doing this awhile back.
ChickenRat
Dustin,
I have an '83 Liquifire and an '84 Liquifire with electric start. If you want, I can see if I can get some info by looking at mine tomorrow. There may be some numbers or something that may be useful on it for you.
Robb
Robb
- JDXspec
- Real Name: Dustin
That would be good Robb. I know I need a keyswitch and whatever else in the e start kit included. Its easier in the JDXs install starter and plug in the e start kit . This is a bit more involved. I would like to get it right the first time.
ChickenRat
I also have instructions on how to install the electric start kit on the Sportfires. Pictures and literature. I bet it's the same or very similar to the Liquifires. I can make a copy and send it you if you'd like.
Robb
Robb
- JDXspec
- Real Name: Dustin
Well If I can get a copy of the installation instructions and the mod instruction I would be in business. anybody have a scan of it by chance? it would save on postage. Thanks in advance
i too wold love a copy of those instructions if someone has them. i ahve a '82 liquifire that i am repairing the elec start on. any docs would be great help.
The Trailfire instructions were on this site, plus I put a copy on vintagesnow.com
yeah, i see them in the other thread now....i was thinking they were two different things. sorry.
A1 SLEDER JIM
i did several . basically the set-up goes like this: the ac from the lighting coil is still regulated and used for RPM, lighting and acces; it is converted to DC with just one diode for the battery charging part; you connect the yellow AC wire under the dash to the new harness; a wire from the new harness takes the DC from the battery and uses it to actuate the solenoid thru the key switch which is now a 3/4" hole size so use a panel knockout tool for a good hole; the battery box has 4 holes to mount to the sled it is easier to drill out the one rivet i the way to mount it and if you need more if just ask. jim
