fuel system questions
kevcboy
Post by kevcboy »
I was wondering what size of fuel line i should be using on my 1973 400, and also i was wondering where i can get a carb kit for the carb, its a WDA32
You have 2 choices 3/16 & 1/4 on some sled the 3/16 is real tight so you will need to heat it up (with a hair dryer or heat gun) on the ends to push it over the fittings. on some sleds the 1/4 is a little loose so you will need clamps to hold the lines on. Your choice??
Now there are different grades or colors of SNOWMOBILE fuel line, spend a little more & buy the better/best fuel line, the cheap stuff gets hard in real cold weather, & it doesn't last near as long, so in the long run you will end up replaceing more often so you'll be spending more.
Just my $.06475 worth
Ken
Any of the catalog suppliers have what you are looking for, Central Snowmobile, Dennis Kirk, Manufacturers Supply.
If you have a local sled or atv store, ask to see their Parts Unlimited catalog.
